Gas Line In Slab - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 09:20 PM   #1
Question
Gas line in slab
We are remodeling our kitchen. We will put in an island with a gas cooktop. Currently, no gas lines in kitchen but do have lines in the attic. We live in Baton Rouge LA. Does anyone know if it is code to run the gas line under the slab (about 3 feet). And does it have to be vented up through the attic out the roof?
pawathome is offline   Reply With Quote
Old 12-26-2010, 09:35 PM   #2
At least here in OK there isn't any problem with that, but I've only ran them through the slab not under by notching out the concrete then filling it in . And it doesn't have to vent out the roof if you have a recirculating power pack, and even if you don't have a recirculating one you can vent it just into the attic if you have the grease filters in. I wouldn't necessarily recommend that, but it will work.
sausagefingers is offline   Reply With Quote
Old 12-27-2010, 03:41 PM   #3
Registered User
Rewards Points: 5,498
May want to check with your local B.D. on running the gas line.... Your H.O. Insurance may not cover a future claim if the installer needs to be certified.
M1505.1 General. Domestic open-top broiler units shall have a metal exhaust hood, having a minimum thickness of 0.0157-inch (0.3950 mm) (No. 28 gage) with 1/4 inch (6.4 mm) clearance between the hood and the underside of combustible material or cabinets. A clearance of at least 24 inches (610 mm) shall be maintained between the cooking surface and the combustible material or cabinet. The hood shall be at least as wide as the broiler unit, extend over the entire unit, discharge to the outdoors and be equipped with a backdraft damper or other means to control infiltration/exfiltration when not in operation. Broiler units incorporating an integral exhaust system, and listed and labeled for use without an exhaust hood, need not have an exhaust hood. http://publicecodes.citation.com/ico..._15_sec005.htm
Gary
Old 12-28-2010, 11:13 AM   #4
http://www.murrieta.org/uploads/form...0in%20Slab.pdf
http://www.scottsdaleaz.gov/Assets/P.../03INT88-6.pdf
Try these links, for CA & AZ but principle is the same, just has to be sealed and vented somewhere other than under the slab.
jeffrow1 is offline   Reply With Quote
Old 12-29-2010, 10:16 PM   #5
remodeling pro
There is no code problem that I know of with this, but you definately want to have the gas work done by a licensed plumber, so he can pressure test the line. Be sure he permits the work, or in the event of an incident due to a gas leak, your insurance company will walk away.
I would recommend that an oversize hole be cut through the slab with a core drill. After the horizontal tunnel is backfilled, this will allow you to fill from the top, leaving no air pocket under the slab.
This hidden slab penetration is a natural entry for termites, so before filling with concrete, go down to the local DIY pest control store and buy the most potent termite treatment you can, and liberally treat the soil in this area.
You definately do not want to exhaust all the food smells and moisture from the hood into the attic; go through the roof. Recirculating, unvented hoods are just a waste of money.
troubleseeker is offline   Reply With Quote
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 11:39 AM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Locate Return Recirculating Line Farmer Dean Plumbing 4 02-20-2009 06:47 AM
