Garage Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 05:16 PM   #1
Garage Framing
Looking for some advice framing a 3 car garage. The garage door wall plans shows one contious header going across all 3 door openings. If I used 3 individual headers (one for each opening) would that change the integrity of the wall? Would the inspector fail me? Thanks.
Ranhome is offline   Reply With Quote
Old 11-10-2011, 05:20 PM   #2
Framing Contractor
You CAN'T change the plans structurally. You WILL fail inspections. You have to ask the architect who drew them. He/she can only make the changes...not you.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (11-10-2011)
Old 11-10-2011, 07:25 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
exactly.
also it creates 2 joints between headers which can act as a mild hinge point . in turn it becomes harder to keep the wall straight. having one contious header will be much larger and stronger plus it will allow for a straight wall
woodworkbykirk is offline   Reply With Quote
Old 11-11-2011, 01:45 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Holey cr@p! You have about a 24' header spec'ed out for your garage doors?
What is it? A 11-1/4" x 18" glulam?
Andy.
AndyGump is offline   Reply With Quote
Old 11-11-2011, 04:33 PM   #5
thats what i was thinking... might even be steel
Old 11-11-2011, 06:50 PM   #6
Framing Contractor
Andy.
Andy...three garage doors will have two breaks between them. Using block where I'm from there will be to short block walls on each side if the middle door. Therefore you don't need a big header whether you use three separate headers or one continues header.
Joe Carola
AndyGump (11-11-2011)
Old 11-11-2011, 07:23 PM   #7
Registered User
Rewards Points: 5,482
The shear walls may be as important as the header ties: http://ohiobuildingcodeconsultants.c...cingdetail.pdf
Follow the PFH here: http://publicecodes.citation.com/ico...002_par028.htm
Did you call and ask the Inspector if you needed a S.E. for the change or not?
Gary
Old 11-12-2011, 03:31 PM   #8
Tizzer's Avatar
Rewards Points: 460
Why are you wanting to change something that you paid money for to design these plans? Cost cutting?
What does the plan show to use there? Is the garage door wall also a gable end. He may be thinking about point loads for the ridge.
Tizzer is online now   Reply With Quote
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 08:04 AM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 06:47 PM
garage door framing Please help craigcr Carpentry 4 10-18-2009 10:55 AM
Garage Framing Question wrldruler Building & Construction 5 08-22-2008 08:26 AM
