-   -   Garage Framing (http://www.diychatroom.com/f14/garage-framing-123019/)
Ranhome 11-10-2011 06:16 PM
Garage Framing
Looking for some advice framing a 3 car garage. The garage door wall plans shows one contious header going across all 3 door openings. If I used 3 individual headers (one for each opening) would that change the integrity of the wall? Would the inspector fail me? Thanks.
Joe Carola 11-10-2011 06:20 PM
You CAN'T change the plans structurally. You WILL fail inspections. You have to ask the architect who drew them. He/she can only make the changes...not you.
woodworkbykirk 11-10-2011 08:25 PM
exactly.
also it creates 2 joints between headers which can act as a mild hinge point . in turn it becomes harder to keep the wall straight. having one contious header will be much larger and stronger plus it will allow for a straight wall
AndyGump 11-11-2011 02:45 AM
Holey cr@p! You have about a 24' header spec'ed out for your garage doors?
What is it? A 11-1/4" x 18" glulam?
Andy.
woodworkbykirk 11-11-2011 05:33 PM
thats what i was thinking... might even be steel
Joe Carola 11-11-2011 07:50 PM
Andy.
Andy...three garage doors will have two breaks between them. Using block where I'm from there will be to short block walls on each side if the middle door. Therefore you don't need a big header whether you use three separate headers or one continues header.
Gary in WA 11-11-2011 08:23 PM
The shear walls may be as important as the header ties: http://ohiobuildingcodeconsultants.c...cingdetail.pdf
Follow the PFH here: http://publicecodes.citation.com/ico...002_par028.htm
Did you call and ask the Inspector if you needed a S.E. for the change or not?
Gary
Tizzer 11-12-2011 04:31 PM
Why are you wanting to change something that you paid money for to design these plans? Cost cutting?
What does the plan show to use there? Is the garage door wall also a gable end. He may be thinking about point loads for the ridge.
