Garage Entry Door Letting In Water - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 05:39 PM   #1
Garage entry door letting in water
I have a detached garage (old, 1941) and the entry door doesn't connect with the concrete, letting water in. Also, the land is sloped downward towards the door and there is a small step down in concrete right before you enter the doorway. I've attached pictures, wondering if anyone has any ideas for attempting to keep the water out. Any help would be greatly appreciated
Garage entry door letting in water-img_0762.jpg   Garage entry door letting in water-img_0763.jpg   Garage entry door letting in water-img_0761.jpg
sejohnson22 is offline   Reply With Quote
Old 10-18-2010, 07:21 AM   #2
Trim the bottom of the door and install a threshold set from big box. Caulk the bottom to the cement and secure with tapcon screws. Be sure you seal the trimmed part of the door bottom.
Old 10-18-2010, 07:59 AM   #3
Household Handyman
Rewards Points: 1,408
A good idea from Bill for sure, but you also need to stand back and try to imagine how water flows in that area and gets into the door. Correcting the drainage is an important step in this also.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
New garage floor with pooling water dtk General DIY Discussions 10 10-08-2010 04:22 PM
Water leaking in garage everytime we use washer! Please Help shigyrl217 Plumbing 3 12-16-2007 08:03 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
