Garage Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 08:35 AM   #1
Garage Doors
Has anyone worked with applying AZEK to a masonite flat panel garage door?
Understanding the weight issues, what do you use for an adhesive and screws?
MJK082652 is offline   Reply With Quote
Old 09-23-2010, 02:21 PM   #2
Try some kind of panel adhesive. Liquid nails is one brand. You can run a bead on the trim, press it into place to distribute the adhesive, pull it off and let it sit for 60 seconds or so. Then you can stick it back on and it should pretty much stay in place. Don't use too much. It's a pain to clean up if you get any squeeze out. Just pin nail it with some brads to be sure it doesn't move while the adhesive dries.
sketel is offline   Reply With Quote
Tags
azek , garage doors
Garage Door Openers / doors BlueBSH Building & Construction 2 07-19-2010 02:35 PM
2nd floor porch over garage doors vtboy51 Building & Construction 5 04-12-2010 08:57 PM
what size header for eve side garage doors? vtboy51 Building & Construction 6 02-18-2010 11:15 AM
Garage doors and openers: repair or replace? walds11 General DIY Discussions 22 02-17-2010 05:04 PM
