Garage Door Header Sizing - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 04:21 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Garage door header sizing
I am building a detached storage building (16 by 24) and planning to install a 9 foot wide garage door in one gable end. ( I will have a regular 36 inch enterence door on an eave side). There is no second story so the only load on the wall is the 1 by 2 pitched asphalt shingled roof. I was planning to used a doubled 1 by 12 header with plywood sandwiched between; and 2 jack studs (cripples) at either end of the header. I did a seach on Google and found a reference that a 1 by 12 header is only good for up to 7 feet.
(I looked in my own garage and found a doubled 1 by 10 spanning a 16 foot door.) Now I am confused, can someone give me some direction?
Old 01-13-2008, 05:58 PM   #2
remodeling pro
Is the 1 in 1 x 12 a typo? I,m guessing you mean a double 2 x 12 with the 1/2" plywood sandwich, bringing it to a standard wall thickness of 3 1/2". This would be plenty adequate for this situation.
troubleseeker is offline   Reply With Quote
Old 01-13-2008, 06:14 PM   #3
A "Handy Husband"
rjniles's Avatar
Yes a typo, I meant a doubled 2 by 12.
Old 01-13-2008, 06:57 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sounds like you should be alright.
As a side point: Do you live in a snow zone? If so, then you will also have the snow load up on your roof too. Something for all DIYers to take into consideration.
- Build Well -
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
