-   -   Garage door header sizing (http://www.diychatroom.com/f14/garage-door-header-sizing-15557/)
rjniles 01-13-2008 03:21 PM
I am building a detached storage building (16 by 24) and planning to install a 9 foot wide garage door in one gable end. ( I will have a regular 36 inch enterence door on an eave side). There is no second story so the only load on the wall is the 1 by 2 pitched asphalt shingled roof. I was planning to used a doubled 1 by 12 header with plywood sandwiched between; and 2 jack studs (cripples) at either end of the header. I did a seach on Google and found a reference that a 1 by 12 header is only good for up to 7 feet.
(I looked in my own garage and found a doubled 1 by 10 spanning a 16 foot door.) Now I am confused, can someone give me some direction?
troubleseeker 01-13-2008 04:58 PM
Is the 1 in 1 x 12 a typo? I,m guessing you mean a double 2 x 12 with the 1/2" plywood sandwich, bringing it to a standard wall thickness of 3 1/2". This would be plenty adequate for this situation.
rjniles 01-13-2008 05:14 PM
Yes a typo, I meant a doubled 2 by 12.
AtlanticWBConst. 01-13-2008 05:57 PM
Sounds like you should be alright.
As a side point: Do you live in a snow zone? If so, then you will also have the snow load up on your roof too. Something for all DIYers to take into consideration.
