Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-13-2009, 03:04 PM   #1
garage ceiling
Currently in my garage, the ceiling joist system is very open. I want to convert some of it to storage but I am concerned how much weight it can hold. The center beam is a 2x10 or a 2x12 laying on its side, running from the garage door to the back of the garage, a span of probably 20 ft. to that beam are runners/joist that span the width of the garage, about 18ft, that are space about 48" apart perpendicular from the center beam, with nothing parallel to the center beam for support. There are also two beams that go from the center beam and connect to the ceiling. I hope that laid out what my ceiling looks like...so onto the question of how much support do i need to add to the ceiling structure to be able to lay some plywood down to be able to stack things up there for storage...thanks in advance
mferguson0414 is offline   Reply With Quote
Old 01-13-2009, 04:46 PM   #2
Moderator
Termite's Avatar
garage ceiling
Is there any way you could post a picture or two? That would help clarify your explanation so we can help you out!
Old 01-13-2009, 11:24 PM   #3
garage ceiling
sure I will on wednesday, I need to take some pictures of my main panel in the basement too b/c I also have some questions about that also
880lb hoist from garage ceiling etriad Building & Construction 15 02-26-2011 05:18 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 03:46 PM
Garage Ceiling CCarlson Carpentry 7 10-05-2008 06:25 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 04:47 PM
