Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-02-2009, 10:53 AM   #1
Default Garage Attic Floor Joists
My garage attic space is constructed of a truss system (2x4) with 2x4 floor joists. I would like to finish the floor for storage above my garage, but the 2x4 construction has me concerned. Will it hold the weight of a person (I'm 250 lbs)?
Would adding scabs between each joist add strength to the floor or am I just wasting time and money?
I don't plan to live up there, but want to be able to walk around to move things around.
Any thoughts on the strength of the existing floor. Thanks in advance
zacmac is offline   Reply With Quote
Old 11-02-2009, 07:52 PM   #2
Remodeling Contractor
The 2x4 "floor joist" is actually called the bottom chord. It will certainly hold your weight, but trusses with a 2x4 bottom chord are not designed to have a floor installed on them. If you put plywood up there and use it for storage, you risk exceeding the maximum load rating of the truss, damaging your roof structure or causing the truss to fail.
eisert is offline   Reply With Quote
Old 11-02-2009, 10:48 PM   #3
I have similar trusses in my workshop - I put down a few sheets of 1/2" ply and store only light stuff there. Christmas decorations, sleeping bags, empty boxes from electronics items, etc. I am not concerned of the weight.
Being over your garage, and if you are concerned, is there anyway to run a beam perpendiclar underneath?
Old 11-02-2009, 11:07 PM   #4
We pick these?
Adding a beam underneath wouldn't help, but it would be unacceptable in terms of altering the structural design of an engineered member. I weigh about the same as you, plus carrying a framing nailer and tool belt weighed down full of tools and nails, and walk around inside roof trusses, actually standing at times on one individual 2x4 bottom chord and I've never had one come apart. I wouldn't store too much up there or you might end up with it crashing down on somebody when they're not looking.
NailedIt is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next thing on our list is going to be the garage band joist air barrier. What that is... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
So the first of the issues that we want to look at is whether or not the neck is warping or bowing in any way. And so we'll use our steel rule, and lay it on the frets themselves in between the strings, in this case, and while it's laying on the edge, we... Read More »
Garage Attic 2x4's jonny3 Carpentry 11 09-25-2009 02:00 AM
Garage Attic Room? Cole660 Remodeling 7 08-20-2009 07:43 PM
Attic Storage Space Above Garage sunthas Building & Construction 5 02-23-2009 02:18 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 06:57 PM
Garage Attic Subfloor wamm002 Flooring 0 07-15-2008 04:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
