Gaps On Trim Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 05:15 PM   #1
Rewards Points: 337
Gaps on trim molding
So I have an Anderson sliding glass door installed, vinyl over wood. The frame is proud of the drywall on the left side by 3/32-1/8". When I am placing the trim molding on I can't get the molding to sit flush on either the wall or the frame,I split the difference and get about 1/16" gap that I would need to caulk on frame side. I can't figure out a way to get it perfectly flat on both sides. I figure I can be the only person who has run into this issue? If it was a wood frame I would have taken a hand plane to it to get the moulding flat, can't do that with the vinyl. Suggestions? I am overreacting to the 1/16" gap?
titan7 is offline   Reply With Quote
Old 02-15-2014, 05:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,.... I always thought that was the very reason caulk was invented,.....
Bondo is online now   Reply With Quote
Old 02-15-2014, 06:00 PM   #3
Rewards Points: 13,250
Got a table saw? If so just stand it on it's end and take some off 1/2 the casing.
Old 02-15-2014, 08:14 PM   #4
A 1\16" gap is very small. Is the trim solid wood or paint grade? If paint grade, caulking is fine. If it's wood, I'd leave it. Again, 1/16" is small.
If it was anything bigger, I'd rip a peice of the same material on the table saw, to the thickness of the gap, and slide it in behind with some glue if possible. Then nail through it.
mcnic is offline   Reply With Quote
Old 02-15-2014, 10:31 PM   #5
Rewards Points: 337
Yeah, OCD is bad with me, I just thought I would check in. Yes this is paint grade so I guess I need to let go.
Trim that is covered by flooring bmbigda Carpentry 12 11-07-2013 03:32 PM
Matching crown molding and other trim tesierowe Interior Decorating 0 01-30-2011 07:06 PM
crown molding gaps at ceiling line Juanita Reis Carpentry 3 12-11-2010 04:33 PM
Satin or Semi-Gloss Paint for Molding and Trim? tdeepness Painting 4 03-29-2010 09:59 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
