Gap Between Wall And Moulding 1/4 ??? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 11:36 AM   #1
Rewards Points: 89
Gap between wall and moulding 1/4 ???
I have installed this wainscoting. And it has turned out pretty nice. I have a question regarding the space from the molding and the wall. The top sill and the wall have a gap of under a 1/4” to the widest point of ½” then back to a ¼”
I like the “Block look” just wondering what the professional way to address this gap would be?
The reason it bows out, is the tile was removed from here, so they had a thick mud bed. YOU CAN SEE THE SPACE WHERE THE COLOR SAMPLES ARE
My thoughts, backfill with mud, (sheetrock compound), find a molding cap, (again I like the block look or cut a piece of wood and apply it to the back (which is the same as mudding it) Any other thoughts?
Thanks again!
chipraynor is offline   Reply With Quote
Old 11-22-2011, 12:38 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why "mud" it if you are just going to add another molding?
I would shim behind the 1X to get a consistant distance from the wall throughout then add another piece (1X2 maybe) as a cap to maintain the square/block look.
Could add cove molding or 1/4" round shot to the wall.
The Following User Says Thank You to Bud Cline For This Useful Post:
chipraynor (11-22-2011)
Old 11-22-2011, 12:47 PM   #3
Rewards Points: 89
Thanks Bud, I didn't plan on mudding, that's the easyiest way. but not sure it would look good. The 1x4 at the top is kinda smoothed down on the corners. Thinking a cap molding is going to be the best!
Old 11-22-2011, 12:55 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A cap of suitable size (1X2) to cover the void and overhang on the front would probably work but if the existing top-piece isn't consistent with the wall the variances will show if it isn't first shimmed to consistency.
What do mean when you say "cap". Maybe we aren't both watching the same game.
Old 11-22-2011, 05:25 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,052
a small cove, 1/4 round or a chair rail style panel molding are pretty much a starndard practice to install on something like that. it will clean it up and you wont have a gap
woodworkbykirk is offline   Reply With Quote
Crown moulding: Flat ceiling to angled wall question RP31 Carpentry 19 10-30-2012 04:18 PM
wall color with moulding terrimomof3 Interior Decorating 2 03-31-2011 04:58 PM
Is it ok to leave a tiny gap between the shoe moulding and the floor? esacasa Flooring 1 09-10-2010 07:22 AM
top moulding for a half wall ryanh Carpentry 5 05-10-2010 09:36 AM
Moulding options for badly warped wall? marc205 Flooring 4 01-21-2008 08:43 AM
