Gap Around Brick Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2013, 09:30 AM   #1
Gap around brick molding
I have a shed that is attached to my home. I just installed a new door frame. I'm trying to install the brick molding; however, I have a big 1/2" gap on the right hand side. The left hand side is a tad bit too tight. Is there a trick to fix this w/out having to take the door frame back off and setting it to the right? Thanks for the help!
VLT49 is offline   Reply With Quote
Old 09-06-2013, 04:09 PM   #2
DIY staff
Rewards Points: 7,174
Not really---pull and reset the door or cut the siding evenly around the opening and cut your own trim to match the new larger opening.
Old 09-06-2013, 09:37 PM   #3
Thank you!
I appreciate the response. Thanks!
Brick molding to seal or not? ekih General DIY Discussions 2 08-31-2013 10:50 AM
Brick molding too shallow for storm door axenol Windows and Doors 7 03-06-2013 09:33 AM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 11:56 AM
Brick molding - pvc vs wrapped aluminum kccooks Windows and Doors 4 07-11-2012 08:41 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
