Gambrel Roof Angles - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 08:10 PM   #1
Gambrel Roof Angles
Hi, I`m new to the message board and don`t know if this topic has been covered before but:
I`m building a barn and want to build a gambrel roof over the center section and lean-to`s on either side.
The center section is 10ft. 3in. or 123in. wide.
Is there a formula for figuring the proper lengths and angles?
Thanks!
sylverfoxx is offline   Reply With Quote
Old 12-20-2008, 01:32 AM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
http://www.google.com/search?q=Gambr...Angles+formula
Brought up...
http://www.roofingchildsplay.com/cal...calculator.php
EDIT
Sorry, dont think that is what your looking for.
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
Last edited by iMisspell; 12-20-2008 at 01:34 AM. Reason: was not paying attention
iMisspell is offline   Reply With Quote
Old 12-21-2008, 11:54 PM   #3
Thanks for the info!
I think I`ve decided to go with a gable roof instead. Might be a safer choice LOL
Old 01-21-2009, 11:45 AM   #4
Home Improvment Contactor
I helped with one of these years ago. It was a brain teaser for sure. Once all the angles were figured out we built a jig. There are 180 degrees in a right triangle. Which is what you have. From the center of the roof to the outside wall and from the top of the wall to the top of the roof. All the angles should end up equaling 180. Draw it first. Goooood luck.
Jack of most is offline   Reply With Quote
Gambrel Roof Measurements Hoff77 Building & Construction 2 03-15-2009 04:54 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
