Gable Vent Replacement - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 10:26 AM   #1
Rewards Points: 77
Gable Vent replacement
Hello All,
Going to replace my 25 year old Gable vents this weekend. Going to go with the Masterflow 1600cfm PG3 here: http://www.homedepot.com/p/Master-Flow-1600-CFM-Power-Gable-Vent-in-Mill-PG3X/100088166#BVRRWidgetID
Same size dimensions as the old Broan ones there now. I still have the paperwork from the Broan ones from 25 years ago if you can believe it.
Anyone make a good recommendation to minimize vibration down the walls? Maybe I need to make a change to the way I mount it or put something in between the brackets and the plywood there now? Rubber, plastic or a 3/4" piece of strapping? Or maybe the ones there now are just so old that a bearing is out of whack causing the vibration??
Any thoughts recommendations welcomed.
Thank You,
~S
Skelleyman is offline   Reply With Quote
ridge vent, gable, moisture in the attic racebum Roofing/Siding 40 03-27-2012 02:26 PM
Best way to vent garage and attic mikeinaz Roofing/Siding 8 03-22-2012 10:48 AM
86 the Gable Vent??? 11thHourZero Roofing/Siding 5 07-17-2011 08:09 PM
Gable vent disaster Navyguy79 Roofing/Siding 5 07-10-2011 05:48 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
