Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-18-2009, 12:30 PM   #1
Gable Trim on Metal Roof
I am building a new garage and I will be installing a metal roof. The garage is only feet from the house which has a shingled roof with 1 ½ " drip edge over cedar fascia on the gable end. I am considering using drip edge over cedar fascia on the gable end of my metal garage roof instead of gable trim so it matches the house. Is this an acceptable practice for installing a metal roof? Or, does the metal roof need the gable trim to keep moisture out?
jm1542 is offline   Reply With Quote
Old 11-18-2009, 12:46 PM   #2
Remodeling Contractor
it should be fine. Trim does nothing to help keep water out. Flashing does.
Old 11-19-2009, 04:58 PM   #3
gravity always wins
Just make sure your metal roof projects out far enough to completely cover the top of the drip edge. Otherwise you'll have a ledge for water to collect on and run back under the metal roof.
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
I'm New & Need Help With Metal Shower Trim dawn312 General Discussion 2 06-06-2009 02:43 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Need Solution to Leaks on Metal Roof Flavio Roofing 13 11-28-2008 03:45 PM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing 2 09-12-2008 09:51 PM
