-   -   Gable Trim on Metal Roof (http://www.diychatroom.com/f14/gable-trim-metal-roof-57462/)
jm1542 11-18-2009 11:30 AM
I am building a new garage and I will be installing a metal roof. The garage is only feet from the house which has a shingled roof with 1 " drip edge over cedar fascia on the gable end. I am considering using drip edge over cedar fascia on the gable end of my metal garage roof instead of gable trim so it matches the house. Is this an acceptable practice for installing a metal roof? Or, does the metal roof need the gable trim to keep moisture out?
Bob Mariani 11-18-2009 11:46 AM
it should be fine. Trim does nothing to help keep water out. Flashing does.
Maintenance 6 11-19-2009 03:58 PM
Just make sure your metal roof projects out far enough to completely cover the top of the drip edge. Otherwise you'll have a ledge for water to collect on and run back under the metal roof.
