Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-02-2005, 12:16 PM   #1
Extreme DIY'r Adk's, NY
Gable Roof returns
I'm framing a detached garage to match an existing house. The house has a different roof pitch do to function over form but I am using the same shingles, siding, windows, etc. The house has returns on the gable ends. These are what I would call half hip returns in that the fascia is continuous and not the shingles. I have never framed a return like this... and since it's not load bearing I'm sure I can figure it out...
what I'm wondering is if there are any hard and fast rules to these? This is one of the few things that I was unable to find any information about online anywhere.
My thoughts are not to try to copy the ones from the house but to make it as long as it needs to be to look good for the scale of the gable face, match the pitch in both directions to the roof. And I'll just use 1/2" cdx here instead of 5/8" OSB. thoughts?
thanks,
Chad
crecore is offline   Reply With Quote
Old 11-02-2005, 04:00 PM   #2
Gable Roof returns
I've never did those returns but i've done alot of hip roofs. 45 degrees on hips makes life alot easier and I think what you will want is like 2 little common rafters comming together with a 45 deg hip in between. Sounds like you have a pretty good handle on it anyway. I'm sure it will look great. HS
K2eoj is offline   Reply With Quote
Old 11-02-2005, 11:25 PM   #3
Contractor
KenTheHandyMan's Avatar
Gable Roof returns
I think you're talking about a Greek cornice maybe? Where just the lower part of the roof sticks out past the gable end and then returns to the siding? If that's right, let me know and I can post a sketch for you.
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
Adding a gable porch to a pitch roof fjacky Building & Construction 5 08-09-2005 07:56 PM
