Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-29-2011, 08:09 AM   #1
Gable End Truss Offset Siding
Hi, I am still working on my shed plans and have some questions about the roof. I am trying to acheive the effect I see a lot on barns where the siding on the gable end truss overhangs the siding on the wall. The top pictures shows what I am talking about. My first question is does anyone know what this is called? Whenever I search for overhang, I get a lot of results about "gable end overhang" which isn't what I am looking for.
My second question is how to do this. I am using a book to help (Build Like a Pro - Building a Shed) and it shows a 2x4 "shoe plate" attached to the inside of the gable end truss that then gets screwed to the top wall plate. Unfortunately it doesn't really go into details and there aren't any good closeup images. How far out can I hang the gable end truss? Does at least some of the truss joist need to rest on the wall plate (like shown in the bottom image)? Or does the shoe plate get lined up flush with the wall plate? In this case the truss would be only supported by the connection between the joist and the shoe plate, which doesn't seem strong enough.
Thanks,
Christian
Gable End Truss Offset Siding-gable-end-offset-siding.jpg   Gable End Truss Offset Siding-shoe-plate.jpg   Gable End Truss Offset Siding-gable-end-offset-siding-frame.jpg
ChristianT is offline   Reply With Quote
Old 07-29-2011, 08:39 AM   #2
Depends on how far you're wanting to set it out as to the wood dimension used. Around here it's a common practice to set the gable ends out to extend over the brick. The engineers at BMC had us using a 2x 10 like a stud on the top plate line set at 24" OC with the backside of the 2x 10 flush with the backside of the plate. That gave us a 5 3/4" projection of the gable end. The gable end was face nailed to the 2x 10. We also squash blocked the 2x 10 to keep things from moving. My framing crew made brackets from scrap 2x 4 that was attached to the wall at each end to hold the gable end in place while they worked on it. Worked well on trusses up to 36 foot anyway.
TrapperL is offline   Reply With Quote
Old 07-29-2011, 10:21 AM   #3
Thanks for the reply. From what I understand, your solution looked similar to the one I have except that the shoe plate was a 2x10 rather than a 2x4 and the 2x10 was flush with the back of the wall plate and extended well beyond in front. Is this right?
Thanks again,
Christian
Old 07-29-2011, 12:42 PM   #4
No, the 2x 10 is installed like a stud, vertically, 24" oc. It's nothing like your pic. Squash blocking is a 2x 4 nailed tight between the vertical 2x 10's so they can't move. The correct terminology for this type of application is called cantilevering the gable end trusses.
Looking at the drawings you have posted, it appears that the truss is still carried on the plate line, just moved out some for a shadow line. The method you have posted will work as long as 1/3 of the thickness of the truss is bearing on the plate. Otherwise, you're putting the wood in a shear load and wood doesn't do that well especially when it's the thickness of a 2x that's in shear.
Old 07-29-2011, 01:47 PM   #5
Ok. That makes more sense. Does the below image look something like what you did? Otherwise, it sounds like I am good with my original method if I only want 3/4 of an inch overhang.
Thanks again,
Christian
Old 07-29-2011, 02:15 PM   #6
Tizzer's Avatar
You're going to go through all that just for 3/4" ?
Why not fur out the gable truss with 3/4 boards. Or set a regular truss where the gable one would go, and nail the gable truss to that for a 1 1/2" overhang.
Tizzer is offline   Reply With Quote
Old 07-29-2011, 02:19 PM   #7
Yeah. I'm probably going a bit over the top at this point . Those ideas you gave are good. I will probably end up doing something simple like that. I just got curious about how it should be done for bigger overhangs.
Thanks,
Christian
Old 07-29-2011, 04:54 PM   #8
That's it exactly Christian. You do good work. I looked for about 30 minutes on the net trying to find a pic for you and couldn't. I thought about drawing one and scanning it to post but you've saved me the time. If all you want to set the truss out is 3/4", meaning half of the truss will still be on the plate, the original is a good method.
The Following User Says Thank You to TrapperL For This Useful Post:
ChristianT (07-31-2011)
replacing rotted siding on gable roof psd7.3 Carpentry 3 07-14-2010 02:27 PM
New siding on house,,end of porch half gable finish? 4just1don General Discussion 1 07-03-2009 07:08 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
