Furring Strips Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 09:03 PM   #1
Unhappy
furring strips help
I'm hanging furring strips for my ceiling and they been in my room for about a 1 1/2 months. they are turning blacker everyday. what is happening to them, what should I do and can I still use them?
Thanks Level
HELP!!!!!!!!!!!
Level is offline   Reply With Quote
Old 05-17-2011, 09:07 PM   #2
DIY staff
Rewards Points: 7,174
The wood was damp when you bought it---or stored it--that's just something some wood does.
The darkening should not affect the soundness of the wood---if it's dry go ahead and use it.--Mike--
Level (05-17-2011)
Old 05-17-2011, 10:40 PM   #3
Rewards Points: 5,336
The black stuff might be mold. Wet wood bundled together, stacked up on top of one another. You might want to check it out first.
Ron
Old 05-18-2011, 05:00 AM   #4
Ron
what is an easy&quick way to test for mold?
thanks Level
Old 05-18-2011, 08:14 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
The cheapest, quickest way to test for mold is on the front of your face. If it looks like mold and smells like mold....... it's probably mold. Sand it off outside and seal it. A lot of wood that is bundled and gets rained on developes a mild infestation of mold. Not anything to worry too much about. Keep in mind that some wood developes mineral streaks that are natural and are not mold. They don't sand off like mold.
Old 05-18-2011, 08:25 AM   #6
looks kind of like some scrap wood that i have sitting on the slab in my old barn. is the wood sitting on a concrete slab? if so, has the slab or the wood gotten rained on, or otherwise damp?
1910NE is offline   Reply With Quote
Old 05-18-2011, 09:18 AM   #7
Registered User
Termite's Avatar
Wood doesn't just turn black as part of the seasoning or aging process. I'd imagine it is some sort of mold. Furring strips are cheap. I'd get rid of them and get some new (dry) ones. Or even better, go with metal hat channel for the ceiling...It is better anyway.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
What size screws for furring strips on rafters TomFl Building & Construction 1 03-15-2010 08:59 PM
Attaching 12/2 wire to Furring Strips blaze01 Electrical 2 02-17-2010 02:17 PM
Plywood over furring strips? sandyman720 Roofing/Siding 5 01-19-2008 10:46 PM
Best furring strips? J187 Building & Construction 5 06-03-2006 10:41 AM
