Originally Posted by pjordan4477
I wanted to hang it on a basement wall, run electric from a box below and get it centered. Problem was the STUDS were not centered.
I believe most TV wall mounts will allow the TV to slide laterally a considerable distance. I know for a fact that there are at least
some that do.
Studs are where they are - which means they're rarely located ideally for centering a TV, which is precisely the reason these wall mounts are designed to slide. Mount the mount to the studs, then simply shift your TV over until it's centered.
