Front Door Threshold Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 12:03 PM   #1
Rewards Points: 22
Front door threshold problem
To make a long story short, the contractor who remodeled my kitchen agreed to install my front entry door for free (he was originally going to install a tile floor in the kitchen, but we opted for wood and that cost us an additional 1K, and we hired a seperate flooring company).
He never completely finished the job, and left this gap between the original flooring and the new door threshold. My guess is the new threshold was much thinner than the old one and left this gap. I'm not gonna call him back at this point. Anyone have experience in the best way to correct this for both cosmetics and function?
Thanks,
Rick
Mantaray14 is offline   Reply With Quote
Old 02-13-2010, 01:35 PM   #2
jlhaslip's Avatar
Rewards Points: 366
get a piece of wood cut and shaped to transition from the floor to the door threshold.
taper it at about 15 degrees on the leading edge.
do not nail it to the floor.
nail a spacer to the sub floor between the door and the wood floor leaving a gap between the spacer and the floor to allow the floor to move with climate changes/wood swelling.
nail the trim piece to the spacer only.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 02-13-2010, 01:52 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Did the Kitchen contractor also install the Storm Door?
I question the door Closer.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-13-2010, 02:13 PM   #4
Rewards Points: 22
Yes he did install the storm door as well. What do you question about the door closer?
Thanks,
Rick
Old 02-13-2010, 02:54 PM   #5
Tool Geek
PaliBob's Avatar
I had never seen a door closer installed on the bottom rail.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-13-2010, 02:59 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
they come with 2 nowadays Bob
but look at the threshold adjustment screw [second from left] looks like its distorting the plastic...no?
Tom Struble is offline   Reply With Quote
Old 02-13-2010, 03:40 PM   #7
Rewards Points: 22
Yes, that is another issue as well. During the summer, the door was sticking at that point and I screwed those adjustment screws all the way down! Especially those first two. Now that it's winter I can get a better idea of what's going on. There is a hump right there in the floor (they are all over in this old house, usually where ever you find supports beams underneath, but I don't think there is one there), and with the swelling during the summer months It must cause the sticking, because the pre-hung door is still square with the frame on top. Is there a DIY way to fix this?
Also thanks to Jlhaslip for the advice on how to fix the threshold issue. I have a great local lumberyard and I'm sure thay could cut that to the specs I need. What do I use for a spacer, just any piece of wood will work?
Old 02-13-2010, 04:49 PM   #8
jlhaslip's Avatar
Rewards Points: 366
same thickness as the floor. just about anything will work. leave about a quarter inch gap. put the spacer tight to the door and nail it down. cover with the new piece.
Old 02-13-2010, 11:01 PM   #9
Rewards Points: 22
Thanks again jlhaslip !
Rick
Small cabin moisture problem tstorzuk General DIY Discussions 10 12-01-2010 07:00 AM
Problem - Concrete Porch Slope johnjsa Building & Construction 1 05-21-2009 12:03 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
