Front Door Molding Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 04:02 PM   #1
Question
Front Door Molding question
Looking for ideas on what might look the best (molding-wise) for my new front door that I installed. Below you'll see a pic of it, and as you can see my right side gap is a little bit wider than my left. So the problem I see is that I'll have different looking molding on each side(like a quarter-round on the left side and regular flat molding on the right), and if thats what I have to do, then thats fine but I thought I'd ask for some opinions first. I have the difference in inches between the stucco and the molding that came with the door. In case you can't see that close, the measurements are:
Top left - 5/8"
Middle left - 7/8"
Bottom left - 1/2"
Top right - 1 1/4"
Middle right - 1 3/4"
Bottom right -1 1/4"
Your thoughts are much appreciated.
queezy is offline   Reply With Quote
Old 11-01-2010, 05:36 PM   #2
Rewards Points: 5,336
Unless you're going to reset the door, just paint the wall the same color as the molding.
Ron
Old 11-01-2010, 06:06 PM   #3
jlhaslip's Avatar
Rewards Points: 2,132
I assume that you don't want to stucco those gaps...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-01-2010, 06:32 PM   #4
I guess stucco would be a good looking option, I've just never done it before. I like the idea though, is it terribly hard to do?
Old 11-01-2010, 08:35 PM   #5
It might be a bit of a pain in those tight spots on the side to stucco. You need to put up wire lathe for the stucco to stick to. In my opinion.....if that counts....Stucco would be the proper thing to do. You wouldn't have to worry about the larger part above the door if you stucco too.
169stang is offline   Reply With Quote
To silt fence or not to silt fence that is the question tomseeley Landscaping & Lawn Care 2 08-30-2010 07:13 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Site work question Jonny Homefixer Building & Construction 6 11-02-2006 08:43 AM
