-   -   Free standing pergolas (http://www.diychatroom.com/f14/free-standing-pergolas-25132/)
sunset construction 08-12-2008 09:59 PM
My question to all is with a free standing pergola over patio pavers what would be the best way to secure the post which be covered by stone cast columns. My thoughts are to drill a 1/2" hole in the paver and drive a 24" piece of a number 4 rebar into the hole leaving about 6 inches of the bar exposed in which I would also drill a 1/2" hole in to the bottom of the post where the 6" of rebar would go. Any and all thoughts would be appreciated. Thanks
Termite 08-12-2008 10:21 PM
Hopefully your pergola posts are going to be sitting on a concrete footing, not just on pavers. :whistling2:
If uplift or overturning isn't an issue, a piece of threaded rod (I prefer that to rebar) can be epoxied into the footing and epoxied into the post. Threaded rod isn't a structural connection, so if that's what you're looking for you need to do something like a Simpson post base that imbeds into the footing.
BuiltByMAC 08-13-2008 12:44 AM
How's about you move that pesky paver out of the way, dig a hole, pour a proper footing and drop your posts into the concrete at least 2'. That will introduce a point of rot where post leaves concrete but having that 2' of post buried in concrete goes a long way towards stiffening up a free-standing pergola. Proper flashing will help prolong the post life.
Mac
whiskeykid 08-13-2008 03:20 PM
I used to work for a timber framer, and it always amazed me how many people didn't want a cap to be put on the bottom of an exterior post because it wasn't 'aesthetic'. Like rotten posts are better?
I would cut a piece of torch-on roofing membrane the same size as the post and melt it to the bottom. As far as fastening goes, the rebar idea would work fine as a locator, but probably won't help if the winds get strong enough. For a permanent fixture it's tough to beat a simpson strap cast into a cement footing.
sunset construction 08-15-2008 12:32 PM
Thank you all for replying, I am hoping they do have concete under their pavers with it being part of the pool deck. I think maybe after reading everyones reply that maybe I should use the Simpsons ABU44 with a threaded rod epoxied to the pavers. Thanks :thumbsup:
