Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-28-2007, 11:08 AM   #1
Dom
Framing a window in a load bearing wall
Good morning,
I would like to frame in a 36 x 60" window in a (2x6) load bearing wall. After searching the net I found this information on spanning that distance.
Max Span for 2 inch double headers in feet
Header Size Supporting Roof Only Supporting 1 story
2x6 (6) (4)
If this is correct, how many jack studs would you use? Also, is it a good idea to use a larger header to avoid cripple studs? Would you use 2x4 spacers in betweent he 2x6's or would it be better to nail 3 2x6's together.
Any suggestions. I do not have a picture available but I can take one if that would help
Dom is offline   Reply With Quote
Old 11-28-2007, 12:01 PM   #2
I have gas!
Clutchcargo's Avatar
The span is 36" supporting only the roof?
2x6 should work but it would be a lot easier if you just fill the space with 2x. Leave room for a 2x6 trim piece on the top.
If you're uncertain many lumberyards offer a free service to size headers.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-28-2007, 12:06 PM   #3
Dom
The span is 60" wide. Supporting roof only. Also, do you have any recomendations on temporary support while removing the 3 or 4 2x6's to install the header?
Old 11-28-2007, 02:06 PM   #4
For temp. support you will need to find out which way your trusses run. If they are perpendicular to the wall you are cutting into you can build a temp wall out of 2 by 6 studs and a top and bottom plate or build a header and support the header with 4x4's on each end. If the trusses are parrallel with the wall you are cutting into you can lag bolt a 2x8 or 2x10 to the studs and top plate of the wall and support this 2x10 with 4x4 post at each end.
ponch37300 is offline   Reply With Quote
Old 11-28-2007, 04:28 PM   #5
Woodworker and Contractor
Kingfisher's Avatar
If they are parralle then its probably not bearing the roof load
dbl 2x6 header if the home is less than 20 feet wide
dbl 2x8 header if the home is lees than 36 feet wide
Kingfisher is offline   Reply With Quote
Old 11-28-2007, 07:12 PM   #6
Is this true of hip roofs? Or are all walls load bearing in hip roof construction regardless of the truss direction? I ask because I have a hip roof and may be adding a window as well...
slakker is offline   Reply With Quote
Old 11-28-2007, 08:20 PM   #7
Kingfisher's Avatar
if its a hip roof the truss will not be parallel at the wall. They may be up until the last 4' but they should change and cross the wall. Normaly all wall are load bearing under a hip roof, but with trusses the load can be very funny and they could hold the whole hip end or only the last little bit, as in the last 4'.
Old 11-29-2007, 02:37 PM   #8
Good call Kingfisher. guess i didn't think long enough on the question and thought more on an answer!
Old 11-30-2007, 10:02 AM   #9
Dom
Is it okay to run electrical through the king, trimmer and cripple studs or do I need to go up through the plate into the atic and back down the other side? I am not sure if drilling holes in a 5 foot span will cause any type of structural weekness?
Old 11-30-2007, 04:53 PM   #10
Kingfisher's Avatar
Are you putting the header hard up to the top plate? If not you could run the wire above it through the jacks and cripples or below also. Drilling a 5/8 hole is OK in the jacks and studs, just keep it in the center
Old 11-30-2007, 04:57 PM   #11
Dom
No, I am using a dbl 2x8 which is slightly overkill, so I will have some space for insulation. Thanks for the info, I wanted to make sure I cross my t's and dot my i's before I start to cut. Thanks again.
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
