Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-07-2008, 02:14 PM   #1
Framing a whirlpool deck!
Looking for a closeup pic of a framed whirlpool island with a 45 degree on it. I have a 5' corner unit where I will have 45's to frame. Anyone have a closeup pic. I have an idea what I am going to do but would like to get a second opinion. I was thinking just cut the top and bottom plates at 45's. But what about studding? Really could use a pic for a visual.
MikeVila is offline   Reply With Quote
Old 12-07-2008, 06:04 PM   #2
Building codes guy, Mod
thekctermite's Avatar
Assume you're talking about a whirlpool bathtub in a bathroom...
Use 3/4 plywood for the top and bottom plates. Cut them the same shape using one to outline the other, or cut them at the same time. That way you don't have a weak plate splice at the corner. The plywood can serve as the deck and the plates at the same time.
thekctermite is offline   Reply With Quote
Old 12-07-2008, 06:39 PM   #3
Yes, whirlpool for a bathroom. Corner unit. I am buildint it out of 2x6 lumber. It will have a 2x top and bottom plate and then 2x studs in between roughly 16"o.c. except where there are obstructions due to the jet plumbing or such. I will then use 3/4" plywood, 1/4" Hardie board, and then tile. Just wanted to get an idea of what my 45degree framing members should be like.
Old 12-07-2008, 08:19 PM   #4
sounds good ! do not have pics handy to show you how I have done it in past however I think I can describe it!?
cut top and bottom 2x6 plates with 22.5* angle at ends .place stud (verticles) at shortest side of angle .attach stud 90* to plate and repeat for other side .what you should have at this point is a "V" shaped post from top view.measure the distance from the outside point of plate to the stud then rip on a table saw 2x2's cut at 22.5* down one side .these are the corner blocks that will fill in and make a perfect corner.Ok maybe not so easy to desribe but that work's well for me! I would also recomend the use of a kerdi membrane by schluter or equivalent product on the horizontal surfaces before tile!it will last a longer time and beleive it or not will keep grout from going moldy as fast! take care! build safe!
Orangeguy is offline   Reply With Quote
Old 12-07-2008, 08:31 PM   #5
I got about a halfway visual on it. Any way you could find the pics. You know the saying, "thousand words" and all. Lowes doesn't carry Kerdi membrane do they? I have read about the paint on RedGard I believe it is over at John Bridge forum. I also read not to use drywall screws to attach to wall and floor. The framing that is. What should I use, deck screws? Exterior? Thx again.
Old 12-07-2008, 08:40 PM   #6
I have found that the AQC or deck screws last a very long time and absolutly agree with there use in you application.I would stay away from liquid liners ,they are very high in odour and a mess to clean up .the depot sells kerdi !it is expensive but works so well and is easy to install . I will hunt for a pic of the framing! for you! also use pl on your joints it will keep framing from shifting and poping tile!
Old 12-07-2008, 08:46 PM   #7
Should I use pl or liquid nails between the framing members and the ply? I would really appreciate any pics you have.
Old 12-07-2008, 09:03 PM   #8
PL premium !
Old 12-08-2008, 05:33 PM   #9
Did you happen to come across the photos yet? Thx.
Old 12-09-2008, 01:02 AM   #10
will have to send you drawings none of the pics show enough detail.will work on them asap!take care !
Old 12-11-2008, 08:45 PM   #11
Just getting back to the puter. Thank you for the drawings. Probably common knowledge to many, but it helped me out and I appreciate your time. I made a little progress this evening. Here are some pics:
I am going to make an access panel on the front and right side by the door. I am thinking about using 3/4" oak ply and then frame out openings and then screw a section of the ply there. Cover up the screws with trim pieces to make it look like a recessed piece. Won't actually be recessed but the trim will give that look to it. If you can visualize what I mean. Plan on tiling the deck surface. Still have alot of work to do, especially when you just do some here and there. The framing is still free standing at the moment. 5 individual frames as of now.
framing-whirlpool-deck-whirlpool-progress-001.jpg   framing-whirlpool-deck-whirlpool-progress-002.jpg   framing-whirlpool-deck-whirlpool-progress-003.jpg   framing-whirlpool-deck-whirlpool-progress-005.jpg
Old 12-11-2008, 09:32 PM   #12
jamiedolan's Avatar
Originally Posted by Orangeguy View Post
PL premium !
Is PL better the liquid nails?
Jamie
jamiedolan is offline   Reply With Quote
Old 12-12-2008, 04:45 PM   #13
pl premium has been without fail for me!it holds up even when wet!looks good Mikevila ,just need a couple more 2x6 on that front edge that is where everyone will sit!looks good but no corner blocks!
Old 12-13-2008, 05:26 PM   #14
Yeah not 100percent yet. Like you said, I have to put the studs and corner blocking in the front panel yet. I am going to make the front panel have access to the plumbing and then a side panel for the pump, fixture, wiring.
Old 12-18-2008, 01:43 AM   #15
I smell some SPAM and eggs cooking this morning!
More On This Topic
Learn the meaning of the Whirlpool Whelm blue card and how to play it in 'Magic: The Gathering' in this free card game video from our expert gamer and fantasy game authority. Read More »
This is Rob McManhon for Expert Village. The other method for nailing is toenailing. This is really only used when your plate has to be already in place and it's impossible it would be sitting on the floor so there is no way that you can get up from... Read More »
How to Frame a Wall
How to Frame a Wall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to frame a wall. When you measure to cut your 2 x 4’s, make sure that you measure your wall and then you subtract 3 inches for your top plate and your sole... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on a wall that takes a 45 degree turn. What we want to do is take the two pieces of crown and we will need to cut them both... Read More »
Adding binomials is one of the first things you will learn in algebra. It is fairly easy to do, but it is the first step towards dealing with more complicated terms and procedures. Read More »
Tub Deck Framing FlyBoyd Carpentry 3 10-19-2008 12:32 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing 3 09-19-2007 02:05 PM
deck - beam to post connection (??) brocasArea001 Carpentry 17 06-26-2007 10:54 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
