Framing Wall - What Type Of Nails (Stud To Top Plate) - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 01:12 PM   #1
Framing Wall - What type of Nails (Stud to Top Plate)
Hi Everyone,
I'm starting to finish my basement, and have been framing the interior walls (non load bearing) in the following fashion:
1 - (3) 8d stud Toenailed to Bottom Plate
2 - (3) 8d stud Toenailed to Top Plate
I recently read some codes that concern me. The code specifies top nailing with (2) 16d nails from the top of the top plate. My top plate is already up, so I can't do this.
Is there another code permissible way to toe nail studs in the top plate?
AndrewMo is offline   Reply With Quote
Old 02-26-2013, 02:41 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Probably. What is your building code? What part of the country are you in? Will this be inspected? I'd say your first line of defense would be your building inspector.
brockmiera is offline   Reply With Quote
Old 02-26-2013, 02:58 PM   #3
Rewards Points: 13,458
8D are for toe nailing not face nailing.
woodworkbykirk (02-26-2013)
Old 02-26-2013, 03:14 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
this is for building a typical exterior wall using wood framing members. the 16d face nails provides more lateral and shear resistance than 8d since it has greater penetration and shaft diameter.
you're not building load bearing wall, nor will they have to resist much lateral loads so you should be fine.
BTW, welcome to the forum!
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-27-2013, 07:48 AM   #5
Rewards Points: 196
I know when i framed my walls i built the walls on the floor. Used PT 2x4 for bottom plate and regular 2x4 for top plate and studs. Did 8' sections then i anchored to the floor and shot up into floor joists
Jason34 is offline   Reply With Quote
Old 02-27-2013, 09:13 AM   #6
Roofmaster
Rewards Points: 2,172
8d Nails are 2.5 inches long 10d are 3, and 16d are 3.25. I use 10d for everything as I consider 1.5 inches of penetration plenty. 8d are too short for framing, period. If you toe nail with 8d you have to get so low on the stud that you split it. Too close to the end. I am assuming a pneumatic nailer.
I personally think that metal studs are probably better in a basement, unless you use doug fir exclusively. SPF will twist like Chubby Checker. Especially the crap from orange and blue.
Old 02-27-2013, 10:48 AM   #7
Maryland
Note: If we're talking common nails here, 12d are 3.25" long. 16d are 3.50" long.
Pittsville is offline   Reply With Quote
Tags
framing connectors , nail
framing question Jamie.M Building & Construction 44 11-27-2012 09:16 AM
Stud in middle of tub/shower plumbing wall. CharlieR Plumbing 2 11-06-2012 03:07 PM
Framing Question adding door to stud wall with cross bracing cakenoodle Building & Construction 18 06-05-2012 11:24 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
