Framing Wall Over Garage Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 03:39 PM   #1
We are converting our garage into a living space. We tried to google this but did not really find much. Does anyone have a link on how to DIY this or some tips for doing this? Thanks
horsegoer is offline   Reply With Quote
Old 08-12-2013, 04:17 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
not sure I'm following your comment, are you trying to frame a second floor wall over the garage door?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-12-2013, 04:45 PM   #3
Rewards Points: 13,968
There's hundreds if not more discussions on this site and just about any DIY site on converting garages to living space.
First thing you need to do is post some pictures. There no two alike.
Post exactly what type living space you expect this to be.
What size is it?
Old 08-12-2013, 05:02 PM   #4
Too Short? Cut it Again!
Agreed. Use the search engine to see what has been posted before.
You are going to need to check with your building department before anything else. Are you bound by any neighborhood or historic association rules that will keep you from doing this? You will need to navigate that early on.
It is highly probable that your existing garage slab foundation is not going to be sufficient for a new story, just to start. You are going to need drawings and stamps. And there will be all kinds of code things.
Old 08-12-2013, 05:26 PM   #5
I think what's confusing it your header.
"framing a wall over a garage door"
Over could mean several things.
If this is a single story garage the door needs to go so a wall can be built in the old opening, siding redone, there should be at least one row of block at the bottom of the wall so water does not come in.
To do it right it's best to cut out and get rid of the old apron.
Going to have to come up with a plan to address the sloop in the floor if there is one.
Old 08-12-2013, 07:43 PM   #6
Rewards Points: 878
Sorry everyone!!! I am looking to build a wall to cover the inside of the garage door as the space(garage) is now going to be a den.
Mstrlucky74 is offline   Reply With Quote
Old 08-13-2013, 11:18 AM   #7
GBrackins's Avatar
as joe said, "got some photos" you can post?
Gary
Old 08-14-2013, 11:17 AM   #8
Rewards Points: 274
There should be some pictures so that idea can be more cleared.
alexjoe is offline   Reply With Quote
Old 08-14-2013, 11:12 PM   #9
Rewards Points: 2,212
I think he is talking about removing the garage door and framing it in to be a wall.
Schmaybe?
mae-ling is offline   Reply With Quote
Garage Door Framing help mystic_cobra Building & Construction 4 07-31-2013 09:14 AM
Garage door framing ekimdoog Building & Construction 4 07-23-2011 11:17 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Genie Garage Door Opener - wall switch won't control LIGHT cody21 General DIY Discussions 3 12-10-2010 04:36 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
