Framing A Wall With Ceiling Tiles - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-28-2008, 09:54 PM   #1
Framing a wall with ceiling tiles
I am framing a partition wall that already has ceiling tiles. I am planning to build it and not supporting the top plate. Can it be secured without disturbing the tiles? Would this be similar to building a half wall that has no upper support?
oakaziz is offline   Reply With Quote
Old 07-29-2008, 08:02 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
what type of ceiling tile are we taking about? droped? stapled? glued?. Yes the wall must be supported. you could grab the furring strips with some deck screws to support the top plate if its a furred down tile. or you could install some blocks between the ceiling beams and screw into them. if you have acess to the ceiling above.
Old 07-29-2008, 08:48 AM   #3
It is a dropped ceiling. Would the wall tip over if not supported?
Old 07-29-2008, 03:11 PM   #4
Drywall contractor
Rewards Points: 1,070
Frame the wall out of metal studs. Fasten the top track to the ceiling grid with 3/8" panhead screws. (Home Depot or Lowes in the nail/screw aisle near the drywall screws.) Of course the wall will tip over if it isn't fastened. If someone were to push it or bump into it, the grid ceiling will push up allowing the wall to lean or fall. The ceiling is "suspended" by wires that can flex.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 03:39 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
