Framing Support For Inside Corner On L-Shaped Stairwell - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 12:56 AM   #1
Framing Support for Inside Corner on L-Shaped Stairwell
I am converting a straight run staircase into L Shape Platform. The inside corner of the L is picking up a double 2x10 Header (carring a single 2x10 Joist) and a double 2x10 Trimmer.
There is an existing internal partion below that I know I need to enhance to a post right below the inside corner to support the load.
I am seeking assistance for two things.
1. How to support the corner from below? I provided a diagram of the approach I was going to take of staggering the cuts and supporting with 3 2x4 post built into the partition. Maybe I am over thinking this.
2. How to fasten at the corner? Besides nailing the ends I was thinking of nailplates and angle fasteners. Again the overthinking statement above.
Thanks for the time.
Framing Support for Inside Corner on L-Shaped Stairwell-ccf01232011_00000.jpg
jsoares4 is offline   Reply With Quote
Old 01-23-2011, 07:37 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 112
If you have a wall under your header there is nothing to worry about.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-23-2011, 09:54 AM   #3
Currently there is no wall under the double header. Since the original stair was a straight run, the current partition is unde rthe double trim. I am trying to avoid building a wall under the double header to allow more openness to the room below. Does the triple stud post described above fill the need?
Old 01-23-2011, 03:25 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 112
I am a little thick sometimes, are you saying there is a wall under the trimmer and not the header? If so as long as there is support for that corner that is all that matters.
Jim
Old 01-23-2011, 04:54 PM   #5
Jim -
Your politeness is greatly appreciated, but I'm sure my 2am drywall dusted drawings were not doing justice.
The Double Header will be a new addition to the joist layout to support the L-shaped stairs. The wall in question is running under the original double trimmer. At the end of the wall, I was thinking of a triple stud post to support the weight of the double header and double joist, but cutting them in a way to help the members to provide some blocking for one another. Thats why I was staggering them.
I uploaded a new image of the drawing detailing better the 3 stud post in the the wall on the bottom left and added a perspective as well.
Framing Support for Inside Corner on L-Shaped Stairwell-ccf01232011_00002.jpg
Old 01-24-2011, 08:25 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 112
Jim -
You shouldn't have any problems with the way you plan to do it.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
jsoares4 (01-26-2011)
Tags
framing , posts , stairs , stairwell , support
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing L shaped stair to basement stubborn1 Carpentry 2 02-27-2009 06:49 AM
Support Framing Around Ductwork mfleming Building & Construction 4 12-04-2008 02:45 PM
framing the stairwell mt232 Building & Construction 4 06-30-2007 08:38 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
