Framing For Sheetrocl Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 07:40 AM   #1
Framing for sheetrocl ceiling
I have frame my basement walls for my TV room. Originally we were going to have a drop ceiling but have since decided to go w/a sheetrock ceiling.
Will there be a problem hanging the sheetrock ceiling since I framed w/a single top plate vs double? (I also will be running 2 by's across the floor joists above to clear ductwork and such). It looks like to me I will have enough nailing surface as long as I sheetrock the walls first (screwing into the single wall plate) and then nail the 2x4's across the joists above up against the sheet-rocked wall.
Thanks!
Bill
get2bill is offline   Reply With Quote
Old 04-02-2009, 08:34 AM   #2
Rewards Points: 5,336
You generally do the ceiling first. It supports the edges. You can use construction adhesive as well as blocking to secure the top of the wall drywall if you think you need it.
Ron
Old 04-02-2009, 02:05 PM   #3
Drywall contractor
Rewards Points: 1,070
As Ron6519 said, you're better off hanging the ceiling first. Just nail/screw the top of the board on the wall to the stud. And definitely use drywall stud adhesive....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Best way to flatten/level existing ceiling framing? RolandOG Building & Construction 20 10-13-2008 07:28 PM
Framing a wall with ceiling tiles oakaziz Carpentry 3 07-29-2008 04:11 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
