Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-13-2013, 11:25 AM   #1
Framing questions
Hello, I have some questions. I am starting the plan to finish the basement but I am not sure if I should add extra frame, insulation and drywall or put directly the dry wall in the existing frame. This is the external wall, right now it's having some frame, insulation and vapor barrier, but the pipe for the AC are outside the wall so I am not sure if it's better to try to remove the existing insulation, put the pipe close to the wall (inside the frame) and put new insulation, or add and extra frame and more insulation to cover pipe. I am a newbie, please feel free for any suggestion. I am including a few pictures. Thanks
pavlito24 is offline   Reply With Quote
Old 02-13-2013, 01:00 PM   #2
Framing questions
Is that fiberglass in direct contact with the foundation wall?
If so that's not going to work.
Old 02-13-2013, 01:33 PM   #3
Framing questions
Is the bottom plate, the vapor barrier and the insulation.
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 01:01 PM
Basement framing questions Richo Building & Construction 1 09-15-2011 08:00 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
a few general questions about basement framing pete0403 Building & Construction 6 07-21-2011 01:07 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
