Framing L Shaped Stair To Basement - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 08:39 PM   #1
Rewards Points: 162
Framing L shaped stair to basement
Hi,
I'm going to be framing in a new L shaped stair to access my basement from my first floor. The attached sketch shows my stair layout (black lines), existing floor joists (blue lines), and proposed new joists and load bearing wall (red lines). Am I on the right path with what I'm proposing?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-26-2009, 10:21 PM   #2
Registered User
Termite's Avatar
Looks ok to me, framing-wise. You'll of course need to dig out the slab and pour a footing for the load bearing wall. The footing's size will be determined by local requirements, soil conditions, imposed load, etc. You'll definately need an engineer's guidance to size that footing for you.
Old 02-27-2009, 05:49 AM   #3
Looks ok, but a bit more complicated than need be IMO. I would go with a Lolly or lally columns, http://www.octoberhome.com/articles/...ustcolumn.html as posts and beams. Walls would not be bearing. You will need to dig footings for the columns,but not as extensive as what you are proposing. Still as posted, Permits and some thing in Red ink (Engineered) will be needed. Good Luck...........
mark942 is offline   Reply With Quote
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Stair framing question stubborn1 Carpentry 6 01-18-2009 11:12 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 10:54 AM
