Framing For Drywall Vents - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 12:25 PM   #1
Framing for drywall vents
I am going to put up a dry wall ceiling in my basement. What is the distance from the vent that is code for the frame typically?So between the wood and the metal vent.
Thanks!
zulufu is offline   Reply With Quote
Old 09-11-2010, 09:44 PM   #2
remodeling pro
Thanks!
You should maintain 2" between the wood framing and the vent stack.
troubleseeker is offline   Reply With Quote
Old 09-11-2010, 10:33 PM   #3
HVAC / Plumbing
depends on the vent material.. SW. vent requirs 6'' clearence to combustibles.. DW vent requirs 1''
kenmac is offline   Reply With Quote
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 05:40 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 07:12 AM
