Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-20-2011, 12:34 PM   #1
Location: The beautiful province of Nova Scotia, Canada.
Question
Framing in a corner tub.
We have a 1/2 bath in our basement that my wife and I want to expand to accommodate a new 2 person tub. We have the space in our utility room to move the wall back but my question is with regard to framing for this new tub. Will we need the tub before we rough in the frame? Does the tub have to sit on a sub-floor if raised? I'll have to raise it up high enough in order for it to drain properly. This will save me the agony of jack-hammering the concrete floor. Any suggestions would be helpful.
Vicarious is offline   Reply With Quote
Old 09-20-2011, 02:23 PM   #2
Tileguy
Bud Cline's Avatar
You need to first settle on the tub. There should be a template available after that. The base of the tub must be supported.
2x6 exterior corner framing, tie downs... CamSweet Carpentry 1 08-08-2011 05:05 PM
Framing a basement corner griffinst Carpentry 9 03-03-2011 08:40 PM
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 08:25 AM
Framing a door that is butted up to a corner kntry Building & Construction 10 09-04-2009 10:10 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
