Framing A Carport On A Detached Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2006, 07:57 PM   #1
Framing a carport on a detached garage
I need to get some pitch on what is presently a flat roof carport on a detached garage. Among the challenges i'm facing is how to frame a hip roof on the existing framing...if that can even be done, or should be done.
Is it advisable to run a hip rafter diagonally across ceiling joists? Additionally, if I used the existing ceiling joist structure and did run a hip rafter across them, it would be VERY thin at the outer edge. Can this be accomplished if i put cats in between each of the ceiling joists at an angle that matched the hip rafter to support it?
I doubt this makes any sense..but the overhangs and angles on this roof are going to make putting a hip roof on very difficult.
May just have to bite the bullet and re-frame it as a gable (but of course the city will want it built like the taj mahal !)...which seems like overkill for a carport..AND the back edge of the carport is not square with the garage...it is about a 150 degree angle (the edge of the carport terminates before it reaches the back line of the carport, so it turn at a 150 then back to the back corner of the garage).
Any insight provided would be greatly appreciated.
Regards.
nomagic is offline   Reply With Quote
Old 05-03-2006, 01:18 AM   #2
carpenter
I can help, but I need more info. If you can draw a picture from the top down of what you have and post it
nailbanger138 is offline   Reply With Quote
Old 05-04-2006, 01:27 AM   #3
renovations
Post a photo as well, I, for one, don't understand what you want to do. You want to build a pitched roof over an existing flat roof, correct? Is the existing flat roof connected to another roof? You prefer a hip roof to a gable for what reasons, aesthetic? A hip roof is a deal more complicated to build, though, of course, do-able. Let us know, it sounds like an interesting project.
Bonus is offline   Reply With Quote
Old 05-04-2006, 11:43 PM   #4
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
Have yout ripped roofing and sheeting off?
If it's flat, what kind of roofing is on it now?
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
Detached Garage Insulation Unregistered Building & Construction 2 02-28-2004 04:31 PM
