Framing In Bi-fold Doors - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 01:20 PM   #16
Framing Contractor
Originally Posted by dinosaur1 View Post
I think I'll have to go a different route here. Thanks guys
i don't understand what the problem is. Your question has been answered. You have 4' door and a wider opening. Frame in the opening and sheetrock it and be done with it. If you were to use prehung doors you would make the opening 2" wider. 50" would be the rough opening. If you don't use prehung doors you make the rough opening 49" and then sheetrock that and have a 48" finished opening.
What is the problem?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-05-2011, 01:23 PM   #17
w/out being rude Joe I have no idea what your talking about. I am far from a handyman as you can see. So I should use 2x4 to frame it then sheetrock it from I understood.
dinosaur1 is offline   Reply With Quote
Old 02-05-2011, 01:34 PM   #18
Framing Contractor
You have a 48" wide door right? Are you planning on putting that door in between a sheetrock opening?
Joe Carola
Old 02-05-2011, 01:36 PM   #19
Rewards Points: 5,336
just an opening
Joe told you how it's done. I don't know what route you're about to travel on other than this.
Is this an issue with tools or framing knowledge?
Ron
Old 02-05-2011, 03:18 PM   #20
it's a finished basement that the previous owner didnt have time to put a door on. The doorway is 57" wide.
Old 02-05-2011, 03:19 PM   #21
Ron
framing, just gotta figure what to put in between the gaps.
Old 02-05-2011, 03:30 PM   #22
Go to You Tube and search, "framing a partition wall"? Look at a few videos and see if the process becomes clear. Then look for ,"sheetrocking a wall".
This is the easy stuff. It gets a little complicated figuring out the spacing for the opening when you're putting in a door. The door manufacturer will tell you what finished opening you need to install the doors properly(in the instructions)
After you've processed a few videos, you'll be better set to ask the detailed questions.
Ron
Old 02-05-2011, 03:31 PM   #23
what if I use accordian doors instead?
http://www.homedepot.com/Doors-Windo...ordion%20Doors
Old 02-05-2011, 05:00 PM   #24
Rewards Points: 1,578
Nail a sheet across the opening.
bob22 is offline   Reply With Quote
Old 02-05-2011, 05:01 PM   #25
wow you thought of that all by yourself?
Old 02-05-2011, 05:03 PM   #26
Experienced
Jackofall1's Avatar
But what if he wants to nail 2 sheets, but then again 3 sheets would be better wouldn't it.
Add some wind and you could have 3 sheets to the wind.......
Mark
Old 02-05-2011, 06:02 PM   #27
Mark
Lol. Love it!
Old 02-05-2011, 07:24 PM   #28
Framing Contractor
You put 2x4's in between the gaps. Can you explain what the problem is?
Joe Carola
Old 02-05-2011, 07:33 PM   #29
Problem is left gap is 7 inches. Right one is 5 inches.
What about an accordian door instead?
Old 02-05-2011, 07:54 PM   #30
At some point in this project, you're going to have to decide to put some effort into it. This DIY stuff has a learning curve. If you're not willing to put the time into learning how to do it, as bob said, "put up a sheet."
And so far, he's put more effort into this then you.
Ron
bi fold doors ron08 Carpentry 3 10-09-2010 09:16 AM
trim for hiding track on bi fold doors ron0805 Carpentry 11 02-15-2010 09:59 AM
Framing for two doors at a 90 degree get2bill Carpentry 1 03-30-2009 07:41 AM
Whats the difference between framing interior and exterior doors? Alan Building & Construction 5 06-14-2008 03:34 PM
