Framing In Bi-fold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 09:42 AM   #1
Framing in bi-fold doors
I want to install two 24" bi-fold doors in a rec room backroom storage area, but the space I need to fill is 57 3/4 inches Wide.....Do I use 2x4's or 1/4 plywood to frame it in? Any suggestions?
Pics are below.
https://picasaweb.google.com/pewaukeedp/RecRoom#
dinosaur1 is offline   Reply With Quote
Old 02-05-2011, 09:52 AM   #2
Rewards Points: 1,522
Build out one side to make it fit to recommended width (see instructions; likely 48" finished; don't forget to take into consideration the thickness of your drywall when doing the build out); drywall it to match existing wall; paint, done.
bob22 is offline   Reply With Quote
Old 02-05-2011, 09:57 AM   #3
I would rather have a more stable frame around the opening. Any ideas?
Old 02-05-2011, 10:02 AM   #4
"I would rather have a more stable frame around the opening. Any ideas?"
Yes, as I said: build out one side (use 2x4's) to make one side wider so as to shrink the opening to 48". Sorry I wasn't more explicit. You could build up on both sides but to me that is double work.
Old 02-05-2011, 10:14 AM   #5
Take a look at the pics....
What if I were to cut the existing drywall 4-5 inches let's say on the right side....and I just buy two 30' bi-fold doors?
Old 02-05-2011, 10:28 AM   #6
Framing Contractor
Bob already gave you your answer twice. Your picture shows the door centered ion the opening, all you have to do is frame it in the same amount on both sides. 2x4's is was you use. Now your talking about 30" doors. What do you want to do?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-05-2011, 10:36 AM   #7
I know and I apologize. Your talking to an amateur here. Regarding the 30' doors....if I could just cut the drywall 4-5 inches back and buy two 30' doors instead that would be the best, but take a look at a new pic I just posted. There is a 2x4 behind there so I don't that's a go.
Old 02-05-2011, 12:18 PM   #8
Unless those 2x4s are load bearing, you should be able to cut them out, move new ones in at the 60" or so opening width and use two 30" doors.
You might try to look at some videos or come back here with more questions. Perhaps:
Old 02-05-2011, 12:23 PM   #9
What do you mean by load bearing?
Old 02-05-2011, 12:26 PM   #10
Quick google led to this as representative:
http://www.askthebuilder.com/397__Lo...fication.shtml
If you aren't sure, get someone into your basement who can help with this. It likely is not load bearing as they would likely be metal tubes from floor to upper beam but I'm not there and you are and you have to be sure to be safe with what you are doing.
Old 02-05-2011, 12:29 PM   #11
Definitely. What if I just drywall the open space without putting 2x4's at all?
Old 02-05-2011, 01:30 PM   #12
Framing Contractor
What are you talking about? Your opening is to big. You have to frame it to the correct opening first and then sheetrock it so that you have something to nail the sheetrock too.
Joe Carola
Old 02-05-2011, 02:11 PM   #13
Rewards Points: 5,336
Pics are below.
There are no door jambs on this doorway. Do you want jambs or do you want to keep it just an, "opening"?
Ron
Old 02-05-2011, 02:11 PM   #14
I think I'll have to go a different route here. Thanks guys
Old 02-05-2011, 02:12 PM   #15
Ron
just an opening
bi fold doors ron08 Carpentry 3 10-09-2010 10:16 AM
trim for hiding track on bi fold doors ron0805 Carpentry 11 02-15-2010 10:59 AM
Framing for two doors at a 90 degree get2bill Carpentry 1 03-30-2009 08:41 AM
Whats the difference between framing interior and exterior doors? Alan Building & Construction 5 06-14-2008 04:34 PM
