Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Prev Previous Post   Next Post Next
Old 10-14-2009, 12:25 PM   #1
Default Framing basement metal post
There is a 4-inch diameter metal post in my basement to support the joists and I'd like to know how to finish it. Do I use OSB/plywood and 2x2s and box it up just like I would with the heater duct? Kind a like soffit but vertical?
Thanks.
kupalino is offline   Reply With Quote
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and an insulation inspection on this home. You want to think of knee walls being secured correctly. You can see this house with the... Read More »
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
How to Use a Quick Square
How to Use a Quick Square by Expert Village
Hi! I'm Drew Finn here for Expert Village. We are going to talk about standard hand tools and how to use them. This is a quick square and it is used for framing. I find it very handy around the house just to do quick little jobs. It's got a lip on here... Read More »
Basement Framing Question epeterson777 Remodeling 12 10-11-2009 05:01 PM
Framing up a wall in the basement hankscorpio General Discussion 3 03-03-2009 12:20 PM
Basement Sofits - 2x2 or Metal framing whirly Building & Construction 41 01-29-2009 12:14 PM
basement framing, walls parallel to joists DIY4EVER Building & Construction 8 06-06-2007 05:08 PM
metal framing davidfenton Building & Construction 8 07-07-2006 08:20 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
