Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-03-2011, 10:47 AM   #1
Framing a basement corner
how do you frame a corner in a basement? Where do I start my first stud so when I create the frame corner all my stud marks down the wall are 16" OC?
griffinst is offline   Reply With Quote
Old 03-03-2011, 11:49 AM   #2
This is assuming you are using 2x6. If you are using 2X4 the 5-1/2 measurment would be 3-1/2. You can also turn the second stud on the left wall 90 degrees so that it forms an L with the first one and still creates drywall backing. This will allow you to insulate more easily. Hope that makes sense.
edit: The spacing on the third stud in on the left wall is actually in the wrong spot. The studs should sit so that any 16" incriment will land directly in the center of a stud. In this diagram it would land on the edge of the stud. I will try to find or make a better diagram, but this might get you going in the right direction.
rubberhead is offline   Reply With Quote
Old 03-03-2011, 12:36 PM   #3
Thanks for the diagram. I'm using 2x4's. I'm going to do it this way. http://images.meredith.com/diy/image...DW_053_01b.jpg
Old 03-03-2011, 12:59 PM   #4
I noticed that depending on which sheet of drywall you overlap on the inside corner it will NOT be 16" OC. So the studs should actually be 16" OC from where the drywall actually starts, not from the beginning of the stud. Correct?
Old 03-03-2011, 02:15 PM   #5
Yeah that's a really good point, you can save yourself some cutting by accounting for the thickness of the drywall.
Old 03-03-2011, 03:02 PM   #6
Remodeler
JCarsten's Avatar
[quote=rubberhead;601678]
If you are planning to insulate the wall, the second stud on the first wall should be turned flat- so that you can reach behind and insulate and still have a backer for sheetrock.
Jason Myrlie
www.jcarstenhomes.com
JCarsten is offline   Reply With Quote
Old 03-03-2011, 04:01 PM   #7
old guy contractor
tcleve4911's Avatar
..........what Carsten said........
tcleve4911 is offline   Reply With Quote
Old 03-03-2011, 04:45 PM   #8
Remodeler
JCarsten's Avatar
Nice visual old guy!
Old 03-03-2011, 05:07 PM   #9
MikeKy55's Avatar
One other thing not really asked, but relates to your project framing. You should pop a line on the floor out about 4 to 5 inches and the wall 90º to it. Then check to sure your square. It makes it a lot easier on a lot of the stuff you will be doing if things are square and plumb. Not many basements are going to be truely square.
MikeKy55 is offline   Reply With Quote
Old 03-03-2011, 08:40 PM   #10
Thanks Everyone:
Yes I already chalked the lines 5" away from the foundation walls and used a plumb bob to transfer the lines to the joists and used the 3-4-5 method to square everything. Regarding the insulation, I doesn't matter as I'm installing 3/4" polystyrene glued to the foundation walls and then framing over them. Also my foundation has 1" polystyrene on the outside of the foundation along with the watchdog waterproofing spray. I talked to the inspector and he said by code I don't have to add any insulation on the inside, but I want to make it nice and warm so I hope added insulation helps.
On another note I was thinking about installing the BARRICADE subfloor system. http://www.ovrx.com/basement-flooring.html Any pro's / cons or advice anyone has on this? Is it pointless insulating the walls if I'm not insulating the floor?
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 05:24 PM
Basement Stair Framing clemson726 Building & Construction 4 07-26-2010 06:09 PM
Framing out basement. Stick frame or firing strips? nickm1024cobra Remodeling 9 07-13-2010 02:15 PM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 07:07 AM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 09:38 PM
