Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-12-2009, 12:01 AM   #1
Framing a Basement
Finishing my basement and I was curious what is the best way to attach the framing to the concrete floor? Is it better to bolt them to the floor or use one those nailing guns that utlizes the blank cartridges? 11x24 room completely encased in a block wall construction.
jacads is offline   Reply With Quote
Old 03-12-2009, 07:35 AM   #2
Framing a Basement
Bolts are a lot of work. Powder actuated nailers are quick and sure. And tapcons(concrete screws) work well. Tapcons require a specific sized drill bit and work best with a hammer drill. Any wood touching concrete should be pressure treated, and the fastener must be stainless steel or coated to reduce corrosion due to the chemicals.
Old 03-12-2009, 10:17 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Framing a Basement
2nd Vote: .22 Caliber Powder Actuated Fasteners. Use hearing Protection.
Other Tips:
Make sure you clean the tool daily with a gun (Firearm) cleaning solution, due to the carbon build-up from the firing caps. If you don't, the tool will jamb.
- Build Well -
Old 03-12-2009, 09:17 PM   #4
Framing a Basement
1st preference - .22 cal powder actuated nailer.
2nd preference - tapcons
The nailer is faster, but drilling a few tapcons for that size of a room wouldn't be bad either.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 03-13-2009, 08:55 AM   #5
Framing a Basement
A stainless steel tapcon screw 1/4 x 2 3/4 would do just fine. It is made of a 410 stainless steel and has a climashield coating so that rusting will not be a concern. Drill a hole through the wood into the concrete using a 3/16 x 4" masonry carbide drill bit and a hammer drill. You will get the tapcon into the concrete 1 1/4 " which over the mininum embedment and should have no problem holding the wall in place.
Bronx is offline   Reply With Quote
Old 03-13-2009, 02:19 PM   #6
whirly's Avatar
Framing a Basement
I prefer the Tapcon method. Most boxes of Tapcons from the big box stores come with the Drill Bit.
I like this method because the bottom plate is easily removed if you decide to change the location of a wall.
whirly is offline   Reply With Quote
Old 03-16-2009, 11:21 PM   #7
Woody
Phuture's Avatar
Framing a Basement
Just be careful with either method. if drillig you have to be careful not to drill all the way through your concrete slab. some older homes onl have a 4" slab. drill through it and you could have ground water come in. when nailing, it's possible for the nails to ricochet on you. but as long as your careful either way is cool.
Phuture is offline   Reply With Quote
Old 03-17-2009, 12:04 PM   #8
Framing a Basement
you might want to consider how you are going to vapor barrier and insulate this as well. Some install a one way barrier on the concrete side of new studs with it wrapped around top and bottom plate.
cheers
fixrite is offline   Reply With Quote
Old 03-21-2009, 09:48 PM   #9
Framing a Basement
I used tapcon concrete screws for my steel stud framing, about 80 LF in all, using a hammer drill to drill, and then a hex head bit to set the actual tapcon itself. It really didn't take too long (prob 3 min total per screw, around 1 screw/2 LF), and buying a hammer drill pays off more than one of those guns, since you can use it for myriad uses afterwards.
eyeQ is offline   Reply With Quote
Old 03-21-2009, 11:04 PM   #10
yummy mummy's Avatar
Framing a Basement
I agree, a hammer drill is very useful, and I also used tapcons for attaching pressure treated wood to concrete.
Good luck.
yummy mummy is offline   Reply With Quote
Framing up a wall in the basement hankscorpio Building & Construction 7 11-28-2012 07:53 PM
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 05:24 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 04:20 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 11:54 AM
