Framing Around Vertical Air Return 2'x18" And Is 6 Ft Tall - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 04:14 PM   #1
Framing around vertical air return 2'x18" and is 6 ft tall
H had to have aircondition company install a cold air return in the utility room outside the wall. I want to frame around the duct and install drywall. Can I glue (what kind of glue) or do I need to build a wood frame around the duct and drywall to it? Thanks.
Ikem is offline   Reply With Quote
Old 11-20-2011, 06:00 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
frame it and drywall it. for this sorta thing 2 5/8 steel studs are used quite often. it makes for a frame that takes up less space and holds drywall fine. this method is used all hte time in commercial spaces
woodworkbykirk is online now   Reply With Quote
Old 11-25-2011, 07:57 PM   #3
I had to do this in a rental unit that I owned. Space was limited, so I fastened 1X2 spruce with self tapping metal screws and then nailed the drywall to the spruce.
It worked well and has been without a problem for 15 years.
Deck: how to attach stringers 10Thumbs Building & Construction 6 06-08-2011 12:35 PM
Framing a wooden stud wall to a vertical concrete wall Hrose77 General DIY Discussions 1 04-19-2011 10:39 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
