Framing Around A Clay Flue For A Wood Stove. - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 11:54 AM   #1
Framing around a clay flue for a wood stove.
Hello,
I have a question about the clearance needed between the clay flue and the wood framing members for a wood stove chimney. When we built the house we had them install a chimney for a wood stove. 6 years later we are starting to finish the basement. I am looking for the clearance needed between the combustible framing material and the flue.
I have attached a picture to help describe what I am talking about.
The plan is to attach durock to the studs and install tile for the hearth area.
Any and all ideas/opinions are welcome.
I am located in Virginia
Buda556 is offline   Reply With Quote
Old 05-26-2011, 12:26 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Have you decided on a stove yet?
The installation instructions should tell you the required clearances.
You might also check out hearth.com. There's a lot of great information and people there.
Old 05-26-2011, 12:54 PM   #3
Blondsense,
Thanks for the reply but I don't think the stove instructions would have what I actually need. The instructions would give me the thickness I would need from the face of the studs to the stove but I need the actual distance required from the side edge of the clay flue to where I can place my first 2x4 stud. I can make the hearth area as wide as I want but I need to know how far to keep the studs away from the flue that is penetrating the concrete wall.
Old 05-26-2011, 12:57 PM   #4
DIY staff
Rewards Points: 7,174
Go to the local code enforcement office and ask to see the book on combustible clearances.
They vary a bit by area.
Old 05-26-2011, 03:21 PM   #5
Rewards Points: 5,336
Originally Posted by Buda556 View Post
Blondsense,
I don't think your thought processes are relevant unless you have the instructions in hand. Guessing what they say seems unnecessary.
Look online for stoves. Many companies publish installation instructions online so you can see ahead of time what's needed.
Instructions will vary.
Ron
Old 05-26-2011, 03:58 PM   #6
Ron
But no matter what stove you use the the actual space between the stud and the flue will not change.
I know the deal with the stove instructions. That is giving you the space required between the wall and stove. I need the space between the flue and studs in the wall.
Thanks for the help as it was a lot quicker and easier just calling the building dept.
12" btw in case anyone else is looking for the same answer.
Old 05-26-2011, 05:36 PM   #7
DIY staff
Thanks for the update----they do vary a bit--you have done well.
New Wood Stove tuchodi Green Home Improvement 3 01-18-2011 06:12 PM
Wood Stove installation w/vaulted ceiling SolarCell HVAC 7 01-11-2010 01:09 AM
Painting behind wood stove donnieh1 Painting 4 11-08-2008 09:42 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
