Framing Angle Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 09:53 AM   #1
I'm building a 6 foot square club house for my kids. I'm using 2x2s for studs for the walls.
I want the front wall to be taller than the back wall so the rain will run off. My front wall is 6ft, 8in and the backwall is 6ft, 6in.
I'm getting ready to cut the side wall vertical 2x2's and don't know what angle to cut them at the top so the horizontal, top 2x2 angles appropriately from the front, vertical 2x2 (6ft, 8in) to the back, vertical 2x2 (6ft, 6in).
Look forward to your help.
TexasTim is offline   Reply With Quote
Old 07-10-2011, 10:00 AM   #2
Framing Contractor
How long is the club house?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-10-2011, 10:04 AM   #3
The Clubhouse is 6ft wide and 6 ft long.
thanks
tim
Old 07-10-2011, 10:06 AM   #4
master of none
Wookie's Avatar
Rewards Points: 14
If I am understanding your question correctly...
You are building a 6'x6' square box. You want the roof to slope down from front to back from 6'8" to 6'6".
You want to know the angle in which to cut the top of your studs on the two side walls to achieve this slope, right?
Your angle is going to be 1.59 degrees.
Wookie is offline   Reply With Quote
Old 07-10-2011, 10:08 AM   #5
Wookie:
Thanks for your response. You are correct on your assumptions. Basically a drop of 2 inches across 6 feet.
Thanks,
Tim
Old 07-10-2011, 02:16 PM   #6
Old School
Willie T's Avatar
2 x 2's ????????????
Willie T
Old 07-10-2011, 02:57 PM   #7
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
That's not much of a drop. I would go with at least a 1:12 slope, which would give you a 6" drop and an angle of 4.76 degrees.
WirelessG is offline   Reply With Quote
small porch framing details - question wombosi Building & Construction 0 05-04-2011 09:35 PM
angle grinder question itin1200 Tools 8 07-13-2010 08:07 PM
Noob Question about framing walls lmholmes11 Building & Construction 15 06-13-2010 10:58 PM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 11:56 AM
stupid framing question amakarevic Building & Construction 12 02-23-2008 04:29 PM
