Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-12-2010, 02:36 PM   #1
framing a 30" cased opening with no door (a walkthru)
I need to extend my closet area and decided to use the sewing room next door to my original closet. I have made the 30" opening but am uncertain as to the amount of framing necessary i.e. header and side supports. There is only attic space above this wall area. Can anyone help me with this project?
chrisjohns is offline   Reply With Quote
Old 04-12-2010, 03:09 PM   #2
Maybe post a picture of what you have done so far. This will insure you get a much better result with others answers.
mark942 is offline   Reply With Quote
Old 04-12-2010, 05:27 PM   #3
Solutions (handyman)
I agree with the picture ... if you know how to do that. Generally, if it isn't a bearing wall, you shouldn't have much of an issue.
If you can't add a picture, could you describe the proposed project in a little more detail?
Mark Harvey is offline   Reply With Quote
Old 04-12-2010, 06:47 PM   #4
Thank you both for your replies. I will get with my husband and ask about taking a picture so that I can post it.
Old 04-12-2010, 06:48 PM   #5
Jay123's Avatar
Pictures always help...unless they're blurry phone pics (you know who you are)
Here are a couple of illustrations from this thread How do I Lower Closet Header? , awhile back:
Might help you "picture" what you need to do.
This was an instance where the op wanted to put in a shorter door than was there originally.
J
Jay
Jay123 is offline   Reply With Quote
Framing for New Stair opening Clearance builderjohn Carpentry 3 02-11-2010 11:36 AM
Framing an opening for an attic ladder stubits Building & Construction 3 02-07-2010 08:12 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 11:50 AM
