Formica Countertop Cutting - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-31-2006, 05:08 PM   #1
Formica countertop cutting
Hi
What is the best way to cut a piece of Formica countertop to fit. Should I use a sharp knife to score it or should I use my table saw to cut it? Thanks.
mekanic is offline   Reply With Quote
Old 10-31-2006, 05:11 PM   #2
General Contractor
Are you cutting just the Formica or the finished counter top?
Hammatime is offline   Reply With Quote
Old 10-31-2006, 07:14 PM   #3
747
registered
747's Avatar
Rewards Points: 534
router on finished counter. NOt finished i would try a utility knife and snapping it.
747 is offline   Reply With Quote
Old 11-01-2006, 08:36 PM   #4
renovations
You put the edge piece on first. Rough cut it oversize 1/8" or so by scoring and breaking. Contact cement it on. Clean up the edges with a router with a bottom bearing straight cut bit. Then glue the roughcut slightly oversize top laminate down and router again.
Bonus is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 05:39 AM
Kitchen sink/counter cutting help? Lambo Carpentry 4 06-17-2006 05:50 AM
Kitchen Sink/Counter cutting help? Lambo Plumbing 7 06-08-2006 08:31 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 11:09 PM
