Following Plans And Schedules Of Materials - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 07:29 PM   #1
Rewards Points: 866
Following Plans and Schedules of Materials
Earilier I asked about plans for building a miter saw stand and PaliBob gave me some help on estimating plywood. He also reminded me to consider the saw's kerf when I made my cuts.
I decided not to make the more portable stand, which sat on sawhorses, and build a cabinet style that sits on casters. My questioni is if I am reading the plans correctly. They are at http://www.popularwoodworking.com/up.../290/fea39.pdf
If you want to see the stand and article on building it look here. http://www.popularwoodworking.com/ar...ter_Saw_Stand/
Do I simply get my dimensions from the schedule and set my saw so as to make sure that I cut to those dimensions, after allowing for the kerf? To be careful, I plan on drawing all my cut lines on the wood before cutting.
Klawman is offline   Reply With Quote
Old 12-03-2009, 06:56 AM   #2
DIY staff
Rewards Points: 7,174
Hello again,A word or two on building cabinets--
It's 2 parts Art and 1 part science------------------------
DO NOT CUT THE WHOLE PROJECT FIRST----
Cut and build one assembly at a time--Mistakes will be made along the way--
Make one assembly--check the measurements of what you have built--Then make adjustments on the next step.
I've seen to many unfinished projects because some minor change of dementions rendered the rest of the 'precut' pieces useless.
Remember-Cut,assemble--Measure--Cut,assemble--Measure--This also allows you to make design improvements as you go.
Good luck,Have fun----MIKE--------
Old 12-03-2009, 02:51 PM   #3
Rewards Points: 866
Thanks, Mike.
I am going to get the wood, now. Almost got it last night. fortunatly, the guy at Lowes suggested I look at some other plans first. Meanwhile, I learned that I was reading the cut sheet wrong and would have had Lowes make the initial cut, needed to get the material in my car, at the wrong place. I will measure, measure again, cut and remeasure as I go. Thanks again.
Old 12-03-2009, 06:19 PM   #4
DIY staff
You are welcome,as always.-MIKE-
Tags
miter saw stand , reading plans , schedule of materials
