Folding Stair Hyprerextends At Bottom Rung Section - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-06-2014, 01:16 PM   #1
Folding stair hyprerextends at bottom rung section
Does anybody know why this happening or have a suggestion for repairing the problem? Thanks.
JohnInMempho is offline   Reply With Quote
Old 07-06-2014, 01:38 PM   #2
Lightfoot's Avatar
Rewards Points: 272
could be a number of things. loose or worn hardware, bottom feet cut incorrectly, unit wrong size to begin with. pictures would help, once you get a few more posts.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 07-07-2014, 11:46 AM   #3
I held the bottom rung section in place with a 16th of an inch gap between it and the second section. Then tightened the hardware very firmly. Stair no longer hyper extends like it did and seems to show that it is approx. 3 inches too short which is how much the person convinces me to cut off of the railings I had just sized and "routed" for them. I just used a 1 by 4 and made ralings for the treads and drilled holes where necessary. I think not only was the hardware loose but holes allow for too much play and the hinges get out of whack. I want to make two new railings and swap out hardware and treads. Probably take an additional 30 minutes to an hour.
Bottom plate and notched studs miamicuse Carpentry 7 06-04-2013 09:27 PM
Exterior stair bottom rail clearance 781-mark Carpentry 9 12-31-2012 08:26 AM
Bottom of Stair Doorway spring3100 Building & Construction 16 11-21-2011 09:22 AM
Is it safe to screw into bottom of stair stringer? barlav Building & Construction 3 02-24-2011 03:20 PM
Drywall bottom of stair stringers question hewey24 Drywall & Plaster 2 11-10-2010 05:24 PM
