Floor Trim In Concrete - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 12:37 PM   #1
Rewards Points: 205
I'm trying to nail up concrete baseboard into concrete. I know I can use glue, which I have. But the wall is not very straight and there are place I need a nail to suck the baseboard into the wall. I have a brad nailer but that isn't working so well. Is there such thing as a concrete brad? I have a few more walls to go and need some advice.
My brad nailer is a Porter-Cable. The one that comes with the red pancake compressor. Works great in wood.
CosmicMiami is offline   Reply With Quote
Old 01-27-2014, 09:50 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
tap con screws with hammer drill...
hand drive is offline   Reply With Quote
Old 01-27-2014, 09:57 AM   #3
Rewards Points: 205
Yeah that's what I thought. Was trying to avoid that PIA. I can get some of the brads to grip the block while the glue dries but others don't penetrate and I end up with a mess pulling the brads out. Better to do it the right way first than to chase screw-ups from shortcuts.
Old 01-27-2014, 10:21 AM   #4
AHH, SPANS!!!
if using tap cons counter sink the screw head just enough to putty over it. if you can press against the area with something heavy until the glue sets that works too.
Old 01-29-2014, 02:50 PM   #5
Rewards Points: 144
I don't know how wide of a span you are going over and.That would make a difference but you could buy some 1X4's and cut them to length and springing them into place against the parelell wall as a clamp.You could use redheads.There are many options but without knowing more about the project it's hard to say.I would not want large fasteners in the trim if were my house.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (01-29-2014)
Old 01-30-2014, 07:55 PM   #6
Professional
TotalHomeworx's Avatar
I would use PL premium fast grip
TotalHomeworx is offline   Reply With Quote
Old 02-15-2014, 10:02 PM   #7
contact cement
mcnic is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
