Floor Joist Types (Noise Reduction) - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 11:33 PM   #1
Question
We are starting to look into building another home and I have a question about which type of floor joists are best to reduce the sound of walking. More or less, I want to be able to converse with the builder about this, but need some solid arguments before we have any meetings.
Currently, when someone walks around our house on the 2nd floor, you can hear a rather loud/muffled "boom" sound with each footstep (to the point it shakes our chandelier). I've noticed with other homes (as in my parents') that the floors feel solid (almost like concrete slab) and there is virtually no sound.
I know from the framing they did open web trusses 16"OC attached to a LVL (or LSL ) beam with joist hangers. 3/4" TG Subfloor. Spans are no longer than 14'. If I remember correctly, they are 11" deep.
What kind of floor system is best? Engineered i-josts? Solid lumber? Hangers vs. no hangers.
Could it maybe be cheap (thin) carpet padding?
Furthermore, would it help to bring them into 12" OC?
Thanks for some advice guys!
bparise is offline   Reply With Quote
Old 01-19-2010, 12:25 AM   #2
Rewards Points: 150
In my experience, I like I Joist the best.
Is the span in your home 14' or your parents 14'???
I think the I Joist any of the company no preference
In my experience we have always set them on top of the 2 x 4 or 2 x 6 framed walls with a rim board
A lot of talk with different contractors and reading sounds like a good adhesive and screw it down.
On the framing jobs I have been on, we have used PL Premium or Sika Flex with a 5/8'' tongue and groove sub floor and then screwed it down
I think a rough idea or the distance though would help.
canyonbc is offline   Reply With Quote
Old 01-19-2010, 12:37 AM   #3
Our house is 14' spans, not sure what my parents' is. But I do remember last time I was up to visit them, there was a new home going up down the street (from the same builder). Didn't get the chance to walk through because it was an active site but I do remember seeing the engineered i-joists through their garage. I am going to ask my parents to see if they can maybe get some info out of their builder. They paid close to $450k for their home, not sure if that's relevant or not. We paid 1/2 of that
Although they did glue our subfloor, the majority of the fasteners are nails. There is a screw about every 16" (actually, pretty random). Already a few squeaky floors (house is only 2 years old) and worse off, you can feel the nails popping up under the flooring in the bathrooms. Ick ...
This was our first house, so really a learning experience. The next one, I'm going in fully educated
Once we meet with a builder and get some drawings, i'll probably continue this conversation. I want to be able to hold my own and not cave if they are trying to do it a cheaper way.
Old 01-19-2010, 01:18 AM   #4
Rewards Points: 150
Education is key.
If your going to use nails on any sort - Ring Shank is a must.
Is the noise currently a squeek or a deeper pound?
Squeeking in my experience is the nail moving a little bit
When you say coming up in the bathroom is it carpet? Through vinyl?
Hard to say price wise - when they were built, size of home, lay out of home, stories, how much the land was, etc.
I would also recommend reading some books some of the ones I have read and really enjoyed over the years
Rough Framing Carpentry - Mark Currie
Residential Framing: A homebuilders construction guide
Framing - Walls, Floors, Ceiling, - Fine Homebuilding
Hope this helps.
Old 01-19-2010, 01:28 AM   #5
Education is key.
I didn't think price was really a factor. Not sure if expensive homes tend to be framed better, or really if it's kind of just standard techniques.
We have a squeaky floor in the hallway (carpeted) and in the bathrooms there is vinyl. As you walk across the bathroom floor you can feel the head of the nail coming up and in a few places its actually starting to wear through it completely.
While were on it... can I fix the squeak without having to pull up the carpet? I came across an article that suggested finish nails through the carpet, but that doesn't seem like it would hold.
And more, pulling up the vinyl would be a disaster to hammer a few nails down. how could i go about fixing this, too?
Old 01-19-2010, 02:00 AM   #6
Rewards Points: 150
I think the book was "Rennovation the 3rd edition" maybe be another book I will have to check the library (I really, really enjoy reading) but i remember a section about screwing through the carpet.
I imagine for a fairly low cost not counting the work it will take to move everything off the carpet but pulling up the carpet and screwing it down should not be to bad not sure what it would cost to get a carpet man in there to relay and stretch it
Hope someone else and I am sure in time people will have some other ideas.
Underneath the vinyl no idea at the moment with out ripping it up
Old 01-19-2010, 07:25 AM   #7
Rewards Points: 582
Our Building Regs for new builds mean that the floors must be sound proofed as shown here.
http://www.customaudiodesigns.co.uk/...g/underlay.htm
stuart45 is offline   Reply With Quote
Old 01-19-2010, 11:46 AM   #8
Wow, this is required for a single-family residence? Do you know, off the top of your head, the extra cost/sqft of installing soundproofing like this?
Old 01-19-2010, 11:49 AM   #9
The vinyl actually shouldnt be a problem, now that I think of it. It's only edge-glued and covered with quarter-round at the baseboards. The carpet, I came across this:
http://www.improvementscatalog.com/h...epair-kit.html
No way in hell I am paying $30 for it, but I wonder if the same could be achieved using some narrow screws (like http://www.grkfasteners.com/en/TRIM_0_information.htm)
Old 01-19-2010, 06:03 PM   #10
Rewards Points: 582
Wow, this is required for a single-family residence? Yes, it is for this.
Sorry, I'm a bricklayer so am out of my comfort zone here, but will try and find out for you. I know the acoustic insulation is about 40 metre2.
This system is designed for both impact and airbourne sound. If it's just impact sound you want to reduce the 10mm underlay may help.
Old 01-19-2010, 06:24 PM   #11
Please don't go out of your way to find a cost! I was just curious if you had a quote in mind. For some reason, the impact sound really bothers me. It makes the house sound and feel very cheap. I am trying to figure out my options that are most cost effective.
Thanks for your input!
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 12:25 PM
Noise Reduction of Original HardWood Floors artist082483 Flooring 2 10-09-2008 05:57 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
