sorry did not take a picture but I will. I plan on moving in this weekend. there are pictures on my inspection report but I don't know how to post them
For this issue, I would just cut another floor joist of similar size and fasten directly to cut joist. I would do this for several reasons. One, if the room above has a tile floor, you will see the floor star to crack at the grout lines because of the deflection in the floor. Two, if the floor joist was cut at the top or bottom of the joist, not just a hole or cut in the middle 3rd of the joist, you better play it safe. I have seen many problems with cut joists. Make sure to re-set any bridging if there is any currently in the area of the cut. Some people and contrators will sometimes just screw in a steel gusset plate that locks in both sides and still allows the plumbing to be clear of any plumbing features. One last consideration is where the cut is made to the joist, if it is in the center of the span of the joist you will have a great deflection or "sagging" issue. Play it safe and prevent future problems above the joist. Good luck!
Since this issue was on your home inspection can you talk to your attorney about getting this fix through the seller of the home, or is that a forgone conclusion?
You can try sistering the floor joists so it looks like this, two boards that are similar to your floor joist, and have 3-4 feet on both side of the damaged section, then run carriage bolts through all three boards. :thumbup:
sory I think the file size exceeded the post limit. I am not very good with computers so why the picture didn't appear I dont really know but I sistered the joist and it apears to have worked (no more squeeky floor.)
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
